Online: Soapbox2627
97 Cubic Inch Engine 110 Horsepower
  • R & R Cycles
    R & R Cycles
    Hi Guys,
    Havent submitted anything for a while now, however at R & R Cycles we have just finished building a Street Engine that is totally rideable and it produces 110 Horsepower with 108 Ft-Lb's of Torque, pretty darn good if you ask me.
    If you have read any of our previous postings on this site, or at our website www.randrcycles.com.au, you will know that at R & R Cycles we aim to get Maximum Efficiency out of our Engines without going too wild with Cams etc, we have put together some Kits using some of what we think are the best after market components available, we have spent many hours at the Dyno, Developing and Modifying Parts to get the specific Perfomance out - that our high standard requires.
    This particular 97 Cubic Inch Build has used some other bits and peices over and above our Kit 3, and we have taken the time to do some very careful calculations with regards to Flow Rates and Velocities within the Intake and Exhaust Systems, as well as slightly modifying certain components so they will perform at their best, whilst still keeping the Engine reasonably mild, which in turn will extend the life of this Engine.
    Obviously our Kit 1 is best Value for money as you will acheive potentially 30% increase in power when fitting up this Kit, if you want to get more out its going to cost however its worth it to have your Harley Perfomance and Efficiencey upgraded.
    Please check out our Dyno Page where you can read about our 97 Cubic Inch Build and lots of other technical info, all for Free.
    Rick
    info@randrcycles.com.au
  • R & R Cycles
    R & R Cycles
    Hi Enforcer,
    You can check out the prices of our Kits at our site www.randrcycles.com.au, just go to our Product Storeand then click on Available Horsepower and Torque Kits there you will find an overview of our Kits + the Prices, as a base cost only, you can then go deeper and order extra components, based on which model you have and what parts you want to acquire.
    As required we can also build you an engine that  performs to your specifications, obviously keeping within our strict performance guidelines, so that your engine will perform as necessary for an extended period.
    Regards
    Rick
  • R & R Cycles
    R & R Cycles
    All that is required is that you take the time to look a bit deeper into what each kit offers, by clicking on the Kit3 for example,  there is a more in depth description stating that you will have all gaskets and fitting kits suplied, and at the bottom of that description you will see all the drop down menus that will give you the final price of your parts purchase, before you add them to your Cart.
    The Labour rate is calculated upon the condition of your bike and how many alternative extras you have already fitted that may have to be modified to suit our standard, so that your Engine will perform properly. This will vary widely between each Engine Build, and of course will also depend on if you want carbies and other components modifed as well.
    If you want to know more just send us an email!!
    Rick
    R & R Cycles
    Info@randrcycles.com.au
    The Home of Finely Tuned Machines
    hi iv'e had 126 hp out of a 97ci EVBT back in  1996,   a street riding FXR  axtell3 13/16 " big bore red shift cam  std heads  etc ( mountian  motor ), just thought i would  let the world out there know
  • Firey
    Firey
    Gday I am going to buy a 2009 Fatbob with 7000 ks, standard headers and S/E pipes, large air filter, and super tune only.
    I am after a stage 3 kit, looks like I will be needing new pipes? i don't like real loud, I like the look of 2 to 1 V + H big.
    What pipes would you suggest?
  • R & R Cycles
    R & R Cycles
    We have found that alot of aftermarket pipes look good however they dont do much for performance improvement, in fact they actually take performance out. We use D & D 2 into1's at the moment as we havent found anything else that goes close to the required specifications to create the correct exhaust gas flow, we do not use the standard Baffle with these pipes as it is too restrictive, we have designed and manufactured our own, we can supply you with a set of D & D pipes with our re-calibrated baffle if you wish www.randrcycles.com.au and check out product store, it is noisey!!
    Alternatively as long as the standard engine pipes and balance pipe are in place on your Fatbob, you will be getting good efficient gas flow, if you can put up with them id leave them on the bike.
  • Firey
    Firey
    Ok Cheers, lets see if he accepts my offer for the Fatbob on Sunday
  • SuperGlide
    SuperGlide
    How'd u go?
  • Firey
    Firey
    Got it Today I like it - its tough - I did enjoy my ride home, especially down the hume - Different than my Fatboy to ride home, I need to go over a few things, shocks are set on 3 no give whatsoever, so I will go for 2 and see what happens.
    I need to check the trye pressure, making sure the back wheel is true, I just felt it wasn't right, maybe it is me and going to take some getting used to.
    I know that road and could hammer on my fatty, not today! going through some corners where the Fatboy used to scrap, it didn't - I think I am going to like it when I get it set up the way I want it.
