Online: tussuck, Hilly
Tyre pressure 08 1200 custom
  • keego33
    keego33
    Picked up my new 2008 1200 Sportster Custom yesterday, on the ride home i thought it rode a bit harsh which I put down to being new, checked the tyre pressures this morning, front 34lbs and rear 40lbs.
    I went through the owners manual but could not find the recommended pressures, can someone help me with this.
    Also I was following a mate home in his car, he said he was driving at around 103 kmh but my speedo was reading closer to 110kph?
    Bloody nice bike.
  • keego33
    keego33
    After looking more carefully i found the tyre pressure in the hand book, 30psi in the front abd 36psi in the rear. According to my gauge both were 4psi to high.
  • kingchops
    kingchops
    keego,
    Did you remove the extra 4psi?
    If so did you notice much difference in the ride?
  • keego33
    keego33
    No I have not taken the extra 4psi out, but based on thrus7er comments and the fact that the Harley shop delivered it like that I will leave the pressures as they are.
  • keego33
    keego33
    Thanks for the comments,  i will drop the pressure to the hand book recommendation and go from there.
