Increasing oil pressure at idle
    I cant see it doing any harm,  you should get a little more oil pressure at idle, but mainly more at higher revs.
    Same as Zippers : www.zippersperformance.com/catalogue/showproduct.asp
    It's not as extreme as the Baisley (LMR) spring appears to be.
    Thanks for the info, it all makes sense.
