Gday, looking at fitting my thundermax, very short on time due to work and family.Looking at getting bike shop to do the fit, my question is will I still be able to plug in my laptop to the ecm after the bike shop has fitted the unit and used their laptop to set it up. Can anyone give me some advice here?
yes , they are replacing the ecm, will a second laptop (mine) be able to plug in after the bikeshop, do the laptops get registered with the product ie being a licensed product?cheers
