Online: John.R
BEST TUNER IN ADELAIDE
  • Midnite
    Midnite
    Who is the best tuner in adelaide?
    and the easiest to talk to, another words doesnt have an issue with explaining what they have done.  besides the guy at victor h.?
  • blueystar
    blueystar
    SCOTTY THE HORNY SNOW MAN
  • LOFTYBOB
    LOFTYBOB
    Ray's Cycle Shack in Salisbury has built up some pretty mean drag Harleys, and he certainly knows the insides out of a built Harley engine.
    They have built some rather fast Buells, so should be able to tickle your bike a bit.
    What are your plans for the Sporty?
  • DaveT
    DaveT
    Hi Guys n Gals
    New to the forum but have been browsing for a while, I purchased a 2nd hand 09 sporty 1200 custom in December (bought from a bike shop in NSW), I'm very happy with the bike, a Feb 09 model with only 8500 k on it when I got it now up to 11500.
    I have noticed a bit of popping on deceleration, normally only afer a bit of a blat throught the hills, but I am noticing it more and more, after looking at various threads this seem semi normal, bike has after market S&S slip ons but does'nt have a hi flow filter or had an ECU remap or after market ECU (I'm looking at doing that sometime), today I cleaned out the throttle body (was some muck in it but not what i'd call bad), I can't confirm an exhaust port/header leak but am thinking of replacing gaskets anyway?
    I've also had the engine light set a couple of times, code was P0505 which indcated an IAC problem which lead me to clean the throttly body, this has'nt helped with the popping but may have helped with a high idle problem (again after a hard run).
    Maybe a tune up Scotty, if your interested?
    Dave
  • Midnite
    Midnite
    Scotty, so use the tts to plug into the ecm and go from there? what if i am just running a fuel computer only? can you increase the rev limter safely?
  • Yobbo
    Yobbo
    I tried looking online and in the pages for Ray's Cycle Shack but couldnt find any contact details.
    If they have a dyno I would love to contact them. If anyone could help me out it would be much appreciated.
