Online: Wanderer57
Open Primary
  • Azza
    Azza
    Hello All
    Have seen past forums asking about pros and cons of open primaries. I'm real keen to fit one of the Ultima open primaries to my dyna street bob, the drag style one a because they look great and  they happen to be  pretty reasonable on price. The biggest negative I get is that they can catch your jeans. Id like to hear from anyone that actually has personally had caught their jeans in an open primary. Does it happen if your not wearing tassles,cause I dont . Are they a cop magnet?
    Azza
    I guess it's up to your taste,,, If you like them get one,,,, But Utlima dont made them for Twin Cams
    hi, ultima is not the best brand as time & use will tell  its american made ,  south amercian  , brazill  i think                                            the clutch hubs don't last
  • Azza
    Azza
    Oh
  • Azza
    Azza
    Thanks
    Had seen many ads on ebay etc and wondered why I hadnt found any for twin cams, Any recommendations for similar or good looking open primaries cause I havent seen any i like as much that i d fit?
  • barmahbush
    barmahbush
    I got one fitted on the softail and still got my left leg intact......the rattle at idle turns into a whistle at higher revs.....I like it.......
  • monarofan
    monarofan
    hey Azza, check out this previous thread,
    http://hdforums.com.au/Default.aspx?tabid=71&forumid=24&tpage=1&view=topic&postid=157150#157792
  • Azza
    Azza
    Yeah did check it out. Thanks. Maybe a little prettier than what Im after but nice. Yet to find one with the exact look Im after.
    i road a kick start only shovel with 3" open belt primary drive from 1982 till about 2004 1 million k's, used stock clutch with primo belt drive, latter went to a bandit super clutch, the stock clutch rattled when you pulled in the clutch, stopped when you let out the clutch, the bandit stopped when you pulled in clutch and rattled when you let it out. no problem with my jeans, but a mate road it once and it stuffed up his new jeans. think it was a one man bike. a mate still owns it and still rides it still has the 3"  open belt & bandit super clutch. just the new ones have electric start.
    i would not change my 01 dyna to open belt primary as can,t see the point.
    the top fuel nitro harleys use them but you have to eather pull the clutch out and put a cooling fan on the clutch hub at end of the track, or change belts a lot, as the heat they build up handling 800HP can melt the belt.
  • aussiesport
    aussiesport
    do it bud ......... and post some pik's when ya done :)
