Online: John.R
Dyno Tuners/software/who/where
  • boofhead
    boofhead
    18 years ago
    Gday Stix
    I've got a pC III and had my bike Dyno'd at the local Dealership. The mechanic there seems pretty good. I would like to go and get it done somewhere else though as a cross check though. I didn;t go witht he SERT becuase it was twice the price and I couldn't see the advantage it had over the PC III (Like you though, a mechanic I aint').
    Boof
    18 years ago
    Anybody from Perth had experience using Frasers or Super Cycles to map PCIII's?
    The PCIII site lists Super Cycles as local dyno shop, but have the Street Bob booked into Frasers this Friday!!!  Thought I would see if anyone had any experience....
    18 years ago
    Thanks Crasher.... for $130 bucks I will take it to Frasers.... cannot be much different to the current map.
    Only worry I have appears to be some different vibration in the low rev range. Not really noticed until I put the new pipes on.... not sure if its related. New to HD's so I'm still learning.
    18 years ago
    karl... thanks for the info. will let ya all know how it goes. not keen on paying someone to learn, but would like to see how it pans out and then compare the maps.
  • BACAMICK
    BACAMICK
    18 years ago
    KARL do u remember what they set ur afr at in the pc111 map i have of urs ?
    SCOTTY i recon ill need you to have a sus of it ?
    when i go to coffs next month ive got it bookt in to get a dyno tune up
    18 years ago
    Okay... comments on this forum appear close to spot on... Frasers are learning and that be with a capital "L". Might head down Bunbury way and check out the people there. I did get a reading on the dyno that was max power 74; torque 83; afr between 13 and 14 (around 13.6 between 3.5k - 4.5k), but they did say that they cannot confirm these settings and are waiting for recalibration on their new dyno setup.
    18 years ago
    karl... truthfully, they did bugger all. Problem is I am too diplomatic. I was in there yesterday and was asked how it was running... said okay, certainly starting better.
    When I get got home stuck the laptop on and noted they had ignored what I had loaded and loaded as close a program from the disc to what is fitted to the bike. By the way, this was after I had to supply the disc. All they did was change one, I repeat one setting (throttle 0, RPM 500 setting). All they really did was put it on the dyno. Nuff said….. Looks like a day trip to Bunbury....
  • jct30200
    jct30200
    Reading all this with great interest! Confirms a few thoughts I have had about Frasers - and I don't want to go near SuperCycles (Perth) either. I just bought a VRSCF - I'm going to fit TAB slip ons and the TAB fuel gizmo and see how that goes. If it doesn't work then I had thought of trying the Power Commander unit. My brother has one on his '07 Street Glide - he runs V&H pipes - sounds great - and has had no problems. Seems to me the cheapest part f the whole exercise is buying the damn bike haha
  • Octavus
    Octavus
    Any recommendations for tuning in Melbourne?
    Brian , Easten Big Twin in Bayswater is the Best in Melbourne
  • tjvrod
    tjvrod
    Any recommendations for tuning in Sydney?
  • Spidey
    Spidey
    Hi guys,
    ok pardon my ignorance, I am new to HD and new to EFi. So you guys are talking about when you upgrade pipes and air cleaners, you need to get a new ECU tuner right. So how do you know what Tuner to buy if you go to source your own parts. Because i am thinking of getting for my fourty eight the Vance and Hines RSD Tracker 2 into 1 pipes, with a Joker Machine's sportster high performance air cleaner and then getting the Screamin eagles super tuner Pro. Am i off the mark? Any ideas guys? I was going to get this all fitted down at Deus at Camperdown.
    Any advice is appreciated...
    Cheers, Si
