Online: Soapbox2627, Hilly
DIMPLE PRODUCT'S TO RELEASE SPECIAL Magnetic HARLEY DRAIN PLUGS.
  • MrDimple
    MrDimple
    COMING SOON
    DIMPLE® Products, Announces their new Harley Davidson line of Dimple® Super Magnetic Drain Plugs.
    Manufactured near Charlotte, NC. USA
    www.drainplugmagnets.com  Go to the Harley Davidson page.
    Available at the end of February, 2010, To be shown, demonstrated and made available at the Daytona Bike Week event.
    There is the main plug, the 1/2 X 20 that fits all bikes that have an actual drain plug for their engine oil, transmission and Primary Chain Case.
    07' to present Harley F "Big Twin" series use this plug for the Engine , Transmission and the Primary Chain Case.
    There are only two other Primary Chain Case plugs to be concerned about.
    04' to 06' =uses the 3/8" X 24 Primary Chain Case drain plug.
    Early bikes to 03' uses the 1/8" NPT (National Pipe Thread) Dimple® 1/8" NPT Super Magnetic Drain Plug.
    SPORTSTER'S only need one of the 1/2" X 20, which will cleanse the transmission and the Primary Chain Case Oil and a set of Black Holes for the oil filter to clean the engine oil.
    PLEASE CHECK YOUR BIKE'S SIZES TO BE SURE! THERE MAY BE SOME VARIATIONS ON SOME YEARS
    The Magnets fitted to these drain plugs are the most powerful magnets ever used on a motorcycle.
    They are so strong they actually clean the oil of tiny steel particles that the oil filter cannot get out, even while the engine is shut off!
    Continually reaching out and pulling particles to the magnet like a Black Hole would pull matter in.
    Extending the life of your machine, like no other accessory can........A must have.
    Available as well for any machine on Earth......Consult with us for your needs and PRE-ORDERS  [script removed]rjodoin@carolina.rr.com
