Raked Trees
  • Robbo
    Robbo
    Hi whats the most anyone has raked their bike with raked triple trees and how does the bike handle ?
  • angry
    angry
    fitted a set of 5 degree hawg halter trees to a fatboy,bike handles well,steers good and has never had a problem. was a simple fit ,only took a couple of hours. looks great,they are quality trees. used raked bearing cups a few times but found the bearings dont last too long.
  • Robbo
    Robbo
    Cheers Angry,
                             by all reports what you have just said seems to be the norm, thanks for the feed back.
  • Robbo
    Robbo
    At present I'm looking at 5 & 6, 5degrees in the triple trees and 6inches extra in the fork tubes.
