Nightster - Changes in year models ?
  • 1200det
    1200det
    I`m after some detail regarding the differences in year models ie 2008 compared to 2010 model ?
    Look forward to joining the community upon purchase of a Nightster :)
    Cheers Damien
  • MapleLeafs
    MapleLeafs
    Haha with Harley Davidson, two years won't see a change. Maybe 20 years.
    There wouldn't be very much at all altered, both are EFI. There may be a thread on 2010 models around here that were posted when the 2010 models were annoucned, but the main news in 2010 line were the models that were completely dropped from production.
  • matt
    matt
    The  first ones that came out in 08 had shorter rear shocks, (US model?) other than that I'm not not aware of other changes.
  • pistol pete
    pistol pete
    i have an 08 model built 10th month 07 i know mine is lower the rear shocks are 11 " eye to eye and apparently where problems with fuel pumps if ya have a c on the sticker they are ok check out xlforum.net and do a search think they relesed the olive in 08 to
  • matt
    matt
    Hi mate, ours is a 9/07 build orange,and has lc on the label
  • grafpak
    grafpak
    2010 has the ecm relocated from under the seat to i believe in front of the oil tank and axle size could be different in the front but nothing major..
  • Damon
    Damon
    I understand that the 2008 model year featured the same 11.5-inch length shocks on the rear as the US models, but in 2009 and 2010 model years this changed to the longer 13.5-inch model because fat arse Americans complained that the bike was bottoming out under their burger eat back sides.
    In the 2009 model you could option the rare skull/machined paint job which was around $2000 extra I believe. This was essentially a swirl pattern machined into the sides of the fuel tank and front and rear fenders, then the Willie G Skull painted into the machined areas.
    In 2010 a more pronounced change occurred with the ECU system. This was moved from under the seat (where is sat in a hole that was cut into the rear fender) to in front of the battery box. With this change the rear fender was now made solid without the hole, allowing Harley to release the springer seat optional extra set up. Older models can still have this fitted but you need to move the ECU and fill/replace the the rear fender.
    Note also that the change in ECU location means that items like the Vance & Hines Fuel Pak are different for the 2010 onwards models, requiring a different wiring loom and plug as this was changed on these models as well.
