V & H Fuelpak modes ??
  • nhb006
    nhb006
    Anyone here had a play around with the setting on their fuelpak? -I have & have more questions.
    My 12th month 09 Iron has Stag Short shots, Heavy Breather & A fuelpak, and the bike runs great but the only thing that drives me a little up the wallis I have noticed a hight idle with the fue pak on. - After alot of googling I thoght I'd try adjusting Mode number 1 down. - My recommended setting (FP-3030) has mode one set to "0".
    What I can tell you is that the lower the number entered into the fuelpak on mode one, the lower my Idle is on cold start. - However going the other way and raising the setting will not raise the idle any further than it was previously, when the setting was at "0". - It's currenly set @ "-5".
    Are their any gurus here know know what these modes represent?
    If so, am I going about this the right way?
  • aussiesport
    aussiesport
    what do you call high idle bud?
  • kingchops
    kingchops
    There's no documentation on the Fuelpak to tell you what these modes do.  I tried once to experiement with them when I had one on the Sporty and I got really screwy results.
    There is a U.S support number and email address for the Fuelpak which I found very good, check out the Fuelkpak website.  Send them your question and they will tell you what to do, if it can be done.
  • nhb006
    nhb006
    Thanks KC. - Ive done that, awaiting a reply.
  • kingchops
    kingchops
    This reply was supposed to go in a different post.
  • nhb006
    nhb006
    Im lost too!
    Anyway, received a reply from V & H. - Seems I was on the right track with cold start Idle. - Mode 1 will affect it.
    Also had an issue with a light hesitaion in the low midrange and received info back on how to fix that. - Made the changes they recommended & Fixed the issue.
    They had me change mode 6 to 10 & mode 7 to 12.
    (Interesting to note this is exactly half what the recommended setting is for those modes on my bike / combo as per the V & H Website)
    This has got me thinking.... :)
  • aussiesport
    aussiesport
    well dont keep it to ya self bud !?!?!??!
  • nhb006
    nhb006
    I made some more chanaged to modes 10, 11, 14 & 15....
    Pulls much stronger in the mid-range... Funny that!
  • Cruisesolo
    Cruisesolo
    I wanna put V&H short shots on my nightster!
    Do i need to Fuel Pak, Air breather, Dyno or anything else? or will i be fine with jus bolting these things on?
    Tim K
