Online: beaglebasher, Hilly
FLHTCU Exausts Equaliser
  • Two tone
    Two tone
    Hi. had some screeming eagle slip ons fitted to my 09 FLHTCU. Its only exausting out of one side, Iwas told to rivit up the equaliser but I recon it could be a problem with the computer. has any one had the  same problem
  • LOFTYBOB
    LOFTYBOB
    No problems, every bike that leaves the stealers with after market mufflers has the valve tech screwed open.
    I have done all my bikes myself, no problems.
  • aussiesport
    aussiesport
    same tapey ! put the screw in and it hardly uses the left side pipe ! am thinking of blocking the side off alltogether and ditching the muff and cross pipe etc !! and just run it as a two into one sys !?!
  • Two tone
    Two tone
    thanks for the info took it in for a service and the recall last week and they fixed it up. two tone
