S E slip ons 09 electra exausting out of one pipe
  • Two tone
    Two tone
    Had a set of S E slip ons fitted to my 09 electra glide when new .Had a problem with the exaust only putting out of one pipe, wired open the equaliser on the right hand side that isnt working .Has any one got the same problem.It would be interesting to find out if its a computer problem, as so far I was told to stick a rivet in it.
  • PigironBob
    PigironBob
    Thats what it's meant to do, when I had the Fatbob I put a screw trough it to keep it open.  Now on the '09 bagger I use a TTS for tuning and through the TTS you can set it in the off (open) position and forget it.
  • Lastrain
    Lastrain
    Yeah normal ... restrictive emission control crap, it'll only open up when ya give her a fist full.
    Heaps of threads on here about them.
    Stick a rivet in it to hold it open and get the shop to disable the active exhaust through the computer. Ya may also want to take a look at your active intake, the little flap on the air cleaner can also be removed by cutting it out with a fine hacksaw, very cearfully cut through the pivot on the back side and it will just fall out, be sure not to get the saw dust in your aircleaner.
  • Fat-Boy
    Fat-Boy
    Next time you have her serviced get the flapper disengaged electonically....sticking screws in it will/can fuck it up.....
  • Two tone
    Two tone
    Thanks to all for the info its in for service this week so ill get them to fix it up thanks again Two Tone
