Tool kit
  • hderwa
    hderwa
    Hi guys, new member, 1st post so tell me if I've stuffed it up and done it in the wrong place.
    I have an 09 Heritage and wonder if anyone can give me a list of whats in a Harley Softail tool kit as I have a big tool kit in my
    garage and want to carry all the stuff I should need for the bike but nothing extra.  Don't want to go and buy a new kit cos I've probably
    got most of it already.
    Cheers.
  • ductor
    ductor
    Finileak
  • Firey
    Firey
    Duct tape and Zip Ties
  • Surly
    Surly
    I got the snap on one thru M&M prior to travelling.
    I added a small shifter, leatherman, tyre gauge, blue loctite, small torch, tape n zip ties. Check that the kit has the right axle spanners for your axles as they change at least once between 2000 and 2010.
    Separately I have two ratchet tie down straps, a tyre repair kit and a very small compressor from Slime
    In 11,500kms i needed the suspension pump a few times (Bagger) and the 10mm spanner
    Surly
  • Fat-Boy
    Fat-Boy
    Harley Assist has always done it for me, no tool kit needed.........ever
  • ductor
    ductor
    Brakes
  • Bobtail
    Bobtail
    Seeing that ya have a softail ya realy don't need to carry any tools, now, If ya had a Dyna!!!!......ya would need a workshop following ya.....Just ask Dazza & FYO
    Bt
  • GRUVY HD
    GRUVY HD
    hi Surly,
    where did you get the slime compressor from?
    Gruvy
  • Nightrider
    Nightrider
    On the subject of leathermans.
    Which model do people find most useful on the bike.
    I sell them in my shop would be good to be able to recommend one to riders.
    BB
  • rider
    rider
     Leatherman Wave is the way to go.
  • rider
    rider
    Don't know what's in the OME toolkit, but I reckon you've got two options,
    1. If ya from the old school,
        Imperial Allen Key set,
        A/F combination spanner set,
        torx bit set,
        roll of insulation tape,
        cable ties,
        6" cresent,
        4" mini multigrips,
         one of those double ended small/ large flat & phillips head screwdrivers,
        an old beanie,
        spare battery for the Fob, and ya disc lock if needed
        two $50.00 notes,
        and if ya got room a small finelec.
        (Tip; if ya wanna squeeze all of that into a strap-on tool bag, cut a good single malt whiskey tube to length so the end cap still fits and put the bulk of it in that,,,
         helps keep     the shape of the bag good. [ Much classier than a bit of black poly tube] )
        Are ya still allowed to wear a Leatherman on ya belt ?
    2. If ya from the new school, A Harley Assist card and a bat-phone.
        Good luck, and may you never have to use either.
