Camshaft Bearing numbers
  • Lanoseal
    Lanoseal
    Hi one and all
    I have made the decision and brought Andrews 37H cams for the 09 Uultra. Didnt think to order cam bearings to suit.  Does anyone have or know how to get the relative timkin of similar quality bearing numbers to suit the cam and the bike?  (Help needed here  Scotty)
    Dave
    Scotty is not here anymore.... I am about to fit Andrews 26 and have gone for the Timken b-168 bearings
    hi i think the bearing number for a twin cam is torrington B-148 check with CBC bearings  not that dear.
    hi stix ,  the bearing number B-148 is for pre 07 twin cams,   is the latter 07up  inner cam bearing larger in dia ? than the 99 to 06 models,    i have only done heads  for 07 up i havn't been down stairs as yet, cheers ,                                             as the EVO & earlier models take a torrington B-138  thanks
