883-1200conv..hp figures........
  • grafpak
    grafpak
    hi all , picked up my sporty from the dynotuner and thought i'd post up my results..
    std       883-44rwhp
    stg  1   883-57rwhp/ 54rwtq
    stg  2   1200-84rwhp/83.8rwtq
    the stg 2 build on my bike is -1200barrels & pistons h/d
                                                        -1200s/eagle heads
                                                        -1200ecm
                                                        -pc111&dynotune   by "PTR"
                                                         -freedom pipe
                                                         -s/eagle h-breather
    stg 3 -(still coming) -1250 barrels / stg 3 cams...................................
    Thats a big jump,,,, Well done
  • Surly
    Surly
    Doubling the HP has got to make you smile.
    Surly
  • grafpak
    grafpak
    cheers ,yes its getting there rode it home and i've just stripped out the front forks (not happy with the ride it has gotten to soft-especially under heavy braking!)
  • nhb006
    nhb006
    Grafpak, just wondering, who did your conversion??
    Im looking to do the same at the moment.
  • grafpak
    grafpak
    machine work by trease engineering and assembly by me ....where abouts are you ?
  • nhb006
    nhb006
    Mildura, Vic...
    I've spoke to a couple of people about it, 1 guy in adelaide, that said $1700 ride in ride out same day, But they wanted to bore the stock jugs, which I've heard is a no no for the Iron. - The local tried to sell me a screamin' eagle 1200 conversion kit for $1800! Plus fitting and a race tuner (about $2500 in total from them). I'm sure I can get it all done much cheaper than that.
    I've sent NRHS an e-mail asking bout their 1250 kits & keep the stock 883 heads, which get a good wrap on other forums.
  • nhb006
    nhb006
    So far I'm leaning towards the 1250 kit. - Going to have a chat to my dealer today & see if they'll fit it. - They've been great with the rest of the bike, So I'm sure they'll be all for it.
    Not sure if they'll fash it to stage 1 1200 for me though.... - If they will should be able to get the whole thing done reasonably cheap & I'll just buy a SESPT for it as I get some spare $.
  • grafpak
    grafpak
    hi mongrel, dont bother with the n2's there not much better than stock..
  • grafpak
    grafpak
    if your fitting 1200 heads and a mikuni look at -andrews n4 /s/e 551 /se 536...you have to match the cam with your comp once you have done your conversion...
