f for rkork oil and air pressure levels
  • robert65
    robert65
    could someone be able to help me out .Iam after the frt fork oil level and air pressure for my 94 roadking,I have just installed new seals and polished up the lower legs just need this question answered to finish off.
    thanks.
  • Destroyer
    Destroyer
    Robert, i can't give you exact numbers for your year bike, but 97-98 were around 287ml(each) for the fork legs, and if your around 80 kgs i'd say 12 psi should be fine.
    Hopefully someone else will chime in to confirm or deny.
    I always add an extra 25ml to each leg over what the manual calls for. Make syre both legs have an EQUAL amount.
    Hope this helps.
  • robert65
    robert65
    thanks destroyer,i wish i was 80kilo's, i was along time ago but things have changed iam 102 kilo's , the oil measurement sounds about right,
    thanks for ya help.
  • Destroyer
    Destroyer
    No worries mate. The manual calls for 10 psi for a rider of 150 lbs, add 1 psi for every 25 lbs over that. So i'd say 13 psi should be fine.
  • Destroyer
    Destroyer
    How'd ya go mate?
  • robert65
    robert65
    just put the oil in and air this morning mate have to set it all up will let ya know when i finish
    thanks again.
