oil filter
  • kiwi
    kiwi
    Hey guys just in the middle of an oil change and havnt got a wrench for the filter any ideas on how to get it off without one
  • berms
    berms
    Hi Kiwi, there was a recent thread on oil filter removal tool and a few of the guys posted some handy methods of getting filters off without the special filter wrench. Use the search function and you will find it.
  • Peter
    Peter
    Super cheap actually sell a big pair of pliery looking things to take oil filters off, from memory i think they are about $15.
  • nimo07sporty
    nimo07sporty
    hi kiwi, a cheap trick you could try is to get an old belt and wrap that around and have the bite going against the direction of and twist it off just gotta get that bite right though in correct direction
  • WAGlide
    WAGlide
    A friend of mine mad a filter wrench for out out of 1/2" hollow square bar with a slot cout in it & a piece of seat belt.. You can then put a 1/2" drive ratchet on it. Works well .
  • WAGlide
    WAGlide
    The biggest problem with filters & spark plugs for that matter is that people think that they need to tighten the hell out of the . Off memory for a filter is tightn until seal then another 2/3 of a turn.
    Sump plugs are another one people think tighter is best.
  • andij
    andij
    i use a shockie adjusytin tool .fits perfect like multis ,otherwise get k@n filters wiyh a nut
