Sporty 07 primary/oil change?
  • Rossy
    Rossy
    Does using Mobile V2 oil in the gearbox-primary, cause the gearbox to be 'clunky' when putting into first gear?
    Does the 20/50 oil cling to the clutch plates, and cause the clunking, and stop them from spinning freely, when disengaged?
  • LOFTYBOB
    LOFTYBOB
    Nothing will stop a sporty from clunking when engaging 1st gear. A longer warm up in the morning with plenty of clutch manipulation will lessen the clunk, but Harleys love a good 1st gear clunk.
  • crackers
    crackers
    How else do you know it's in 1st?
    Pro Blend make a Product called Cool Cruisin . Designed for HD Transmisions .They claim that it will stop the Clunk
  • bozhog
    bozhog
    i use this Spectro oil in my rocker and my sportsters primary chain case...it gives very smooth clutch feel & engagement...why would you f**k around with other stuff  for 15 bucks???. its formulated for the job & works very well.. check out my link for all types of spectro oils for harley air cooled v-twins...
    bozhogsharleyoilworks.blogspot.com
    Heavy Duty Primary Chaincase oil
    Product Information ...RRP 1 US Quart $14.99
    Heavy Duty Primary Chaincase Oil
    This sheer stable petroleum is designed to withstand the punishment of high loads, and contains special polymers to provide exceptional clutch engagement and temperature stability. Meets full OEM requirements, and should be used according to manufacturer’s instructions. Formulated specifically for Harley® Sportster and Big Twin applications. Low drag, low friction loss SAE 85w viscosity eliminates clutch “drag” and slipping.
  • jacqui
    jacqui
    Hi Rossy I tried the mobil 1  V twin it realy made the gears clunk so we took the Mobil 1 V twin out and put in Belray oil this oil is thinner and seems to have made the clunck not so harsh Iam still trialing I will take it out for a burn see if there is much difference I will get back to you.
  • nhb006
    nhb006
    Amsoil 20W-50
    hi, doe's it clunk worse 1st on cold start-up or all the time even when hot  if not check clutch adj & pri chain tension  1st,
