SERT to TTS Upgrade
  • harleynt
    harleynt
    I read the problems HogBag07 had with customs in sending over his sert for upgrade.
    Has anyone else sent their SERT for upgrade and how did they send it at what cost.
    How long did it take for the upgraded unit to return to sender.
    I assume that a CD with the software comes with the upgraded tuner.
  • 2005 FLSTFI
    2005 FLSTFI
    Had no problems with customs.
    Took 2 weeks from the time I dropped it off at Fedex & dropped off back to my front door (Perth), at a cost of roughly $200AU for everything.
    CD comes in box with upgraded Interface.
    Mal
  • harleynt
    harleynt
    Mal thank you for your info
  • harleynt
    harleynt
    Today I finally received back from the USA my upgraded SERT tuner.
    Anyone else considering the upgrade be aware that the return freight component is US $95.00
    almost the same as the upgrade
    On the CD i didnt receive any MT files
    I looked on the site and there are many but there is nothing to indicate which ones for which bike configuration
    I have 2007 Fatboy with Vance & Hines Stagged Bigshots and a Kuryakin Skull aircleaner
    Can anyone point in the right direction of a sample MT files so that i can start tuning
    Many Thanks
  • harleynt
    harleynt
    My Laptop that has the TTS programs is not connected to the internet
    I had the update on the CD but this was not able to download any files
    I assume that i need a MT as a base map and this already is setup for tuning
  • harleynt
    harleynt
    My current map is a MT6 files
    looking on the mastertune site and the calibration file information
    the map i need is AE176-002
    but there is no map available on the site to download
    Any help would be appreciated
    Scotty can you point me in the right direction please
    Dave thank you for you quick repsonse
    the MT7 files wont work for me
  • harleynt
    harleynt
    I found on the US site a thread that mentioned that MT6 files were for vehicles without 02 sensors and MT7 files for those with.
    As i found on the mastertune site a file AE176-002.MT7 ( which Dave also sent to me) and downloaded this but received the following error
    Unsupported data type detected
    This file was developed for a different Master Tune-HD Application and is not compatible with this software
    This file type is HDT-176B
    From what i Can see about my software version
    Master Tune_HD for Harley Davidson
    Version 1.0.0 Build Date 15-July 2008
    Vin Lookup 08-October-2007
    Anyone have any ideas
  • 2005 FLSTFI
    2005 FLSTFI
    Harley NT
    Being a 2007 model, you would have O2 sensors so I would use MT7 files.
    I'd say you need the latest versions of Mastertune on your laptop to open up the file you want which are automatically downloaded from internet using TTS Updater.
    Can you get your laptop hooked into an Ethernet cable from someone, to download the files & latest versions, this is what i did with mine & it downloaded all the relevent stuff no problems.
    Mal
  • harleynt
    harleynt
    I ran the update from the CD
    I am unable to update my laptop software as it does not connect to the internet
    I installed it on my work pc but evidently wont allow me to download (firewall problem) the update
    does the update download a file that is used to do the update
    or does it update the existing installed file
    as i can try another pc to do an update
  • harleynt
    harleynt
    Thank You Scotty and thank you Dave
    will see if i can connect my laptop to a pc and try to access the internet for the update
    If I have no luck I will see if you can upload the updates for me on a server
