Apehangers on 2010 sportser
  • Derek
    Derek
     What do i need to change   apart  from handle bars to put apehangers on and how much would it cost
  • kingchops
    kingchops
    You will need longer throttle and clutch cables and you will need to extend your wiring to the switch housings. Cost, depends on where you get it from. I'd try looking for a kit that includes everything you need in a package. I've seen some on U.S ebay, do a search.
  • grafpak
    grafpak
    what size ape hangers ?
  • Derek
    Derek
    Thanks,  is it just as simple as unclamping standard bars and replaceing with mini ape hangers and lengthening cables, ill have to relocate indicaters as well ?
  • Derek
    Derek
    Just a set off mini ape hangers
  • Nightrider
    Nightrider
    licks do a bar kit with everything you need to extend cables wires etc.
  • BAKES
    BAKES
  • Frank7214
    Frank7214
    Check out Hills Country Custom, they do a complete narrow ape hanger kit.
  • skullster
    skullster
    I put 10" apeson my nightster and the only thing i had to change was the brake lead i got bars and lead off mates dyna
  • Taffymarsden
    Taffymarsden
     How different is the ride using apes? Looks darn awkward.
  • Fatcat68
    Fatcat68
    I put mini apes on the old girls nightster she loves it Reckons they should come out as standard issue
    Just needed to buy new Braided Brake line
    Cheers Fatcat68
  • BAKES
    BAKES
    Taffy I agree they do look awkward, but once you are behind them, they are a very comfortable.
    no getting use to, just ride
  • Nightrider
    Nightrider
    http://www.brcustomcycles.com/
    These guys got great selection of bars and some very good videos on how to fit them.
    FYI
