Online: Soapbox2627
Can someone make a baffle for me???
  • Dermie
    Dermie
    I am not having any success in getting a new baffle for my Screamin Eagle muffler that I have lost. So I was wondering if some one could make one for me????
    23012010.jpg picture by Dermie_photos
    The pipe  is about 1 to 1.5mm thick, The r/hand side is one piece with the holes, the pressed in flute & the flared end. The bell at the l/hand end is another piece of pipe stepped down & is brazed onto the smaller tube/pipe in four places. I can measure it & send the dimensions to you. I reckon it is sort of a bit of plumbing fabrication.
    My bike sounds like a bloddy sewing machine with the standard pipes on, the sound or lack of, is driving me mad.
  • Lastrain
    Lastrain
    Have you tried a dealership for a new one ????
  • Chromy
    Chromy
    If you dont have any luck, I can make them for you. Just need a drawing with specific measurements. Take about a week given my other commitments.
    Chromy.
    Sonic or outer cycle in VIC make that type of baffle, someone here might know there contact details?
    good luck mate, i have Sonic Tappered end Duels on my twin cam 95" Dyna best time 11.28 best trap speed 121mph registered but i choose to only race these days
    Here is a link to the only time ticket i have online, i had to post it to USA to get my friends to do the link as i'm hopeless with PC's, this was 4 years back when i road my bike everywhere, but same cams same pipes just pistons & head change since & the rider is also older i'm Lakes you can tell by my race No 1314
    http://www.bishopsperformance.com/images/proof/LakesTimeTkt0206.jpg
  • Dermie
    Dermie
    Yes I did but it appears they have to do some "research"??
  • Dermie
    Dermie
    Chromy. That time frame would be ok, how much do you reckon it would be$$, roughly,!!
  • braando
    braando
    Hi Dermie.............i have a set of se baffles floating around..........."slightly" modified but may help you out.....PM me with an email address mate....brian
  • Dermie
    Dermie
    Not sure how to email you directly braando, hope this does not get me all the spam in the world but you can call me on my mob also
