49mm front end buy/swap
  • grafpak
    grafpak
    hi guy's ,just posting to see if anyone with an 2006-2010 dyna (with 49mm forks) is looking to change/upgrade there front end to maybe a springer??or upside down forks etc ???i have cash for a pair of complete 49mm fork legs in good working order asap?!?!......just thought if someone is tossing up a change the cash incentive might help out (i'm a good bloke !)
    ..................................cheers..dc..
  • mat351
    mat351
    Hey DC,
    I just finished a WG conversion on my '09 super glide and have a set of standard tubes (no lower halves), triple trees, axle and Mag/disc/tyre all up for sale if any of that
    helps.
    Cheers.......Noose
  • grafpak
    grafpak
    hi noose, new front looks good i'm guessing you went wide glide with longer tubes, what rake did you add??
    only thing i might be able to use is the axle hit me with a price??and where abouts are you?..cheers..dc..
  • grafpak
    grafpak
    cool , i might get a complete set between you 2 !! "tubes/lowers/axle...looking good..been looking at genuine hd forks comlete ready to slide in (easy!) and best thing is all models are the same price so i can get the fatbob black forks all ready for twin disc's !!! same price as a std dyna...
  • kickinon
    kickinon
    mat351
    can you post here ?? if you will seperate or you prefere to sell in one foul swoop//
    cost ??or costs??
    what state your in??
    what parts you have left//
    ill keep my eye on the  (parts for sale) page as well in case you list them there...
  • mat351
    mat351
    Hey grafpak, kickinon,
    Bear with me I'm new to the forum thing
    I used OE triple trees off an 08 wide glide (Chicago Harley) (they have 2deg built in), 4" over tubes(Rollies) and tricky stainless 3deg offset stem bearing cups (Vulcan.USA)Added 5-6 deg rake but left me with factory trail (+ a bit) figures.
    Machined axle spacers down to 15/16 to suit custom 21" wire wheel with floating disc (Rollies). 2mm spacer behind caliper mounts. Chrome lowers but got them under warranty for corrosion..... and geezus I had to squeeze the bast***ds to get 'em
    Prices on bits leftover.... STD axle -$25. STD 49mm tubes -$90. Trees/stem/bearings-$150. F.Mag/disc with 75%tyre-$200.
    Or make submissions ....lol all freight at buyers expense but I will do my best
    I live in Cairns Qld.....sorry , a bit out of the way
    Cheers to all...........Noose
