Online: Soapbox2627
DOT4 bubbling paint
  • whiteyluvsrum
    whiteyluvsrum
    Dam you DOT4!
    Ive searched around & it looks like a common problem. For those that have had it replaced did HD have a solution to the problem & fix it?
    Is it worth changing to DOT5 and changing the fluid more regularly or sticking with the 4 & changing the cylinder lid regularly?
  • AJ56
    AJ56
    I had that on my softy and ended up getting a chrome cover.
  • Jake Adelaide
    Jake Adelaide
    Nothin wrong with chrome.... Thats what i'll do to the Dyna, thanks for the info.
  • whiteyluvsrum
    whiteyluvsrum
    I don't mind chrome but the train is black and I wanted to keep it black.
    Its still under warranty, so ill just get it replaced while its free and think about chrome when it eventually happens again.
    What a fucken pain!
  • jordan
    jordan
    there is a new cover that will retro fit, if you get it warranty that is what you will get. the cap has bosses around the screw holes to set the tension, problem solved, DOT4 is a better fluid for street use over DOT5
  • Fat-Boy
    Fat-Boy
    I had mine replaced a few months ago as a warrenty thing. Was told that part of the problem is that the master cylinder gets over filled to begin with. I now have less fluid in there and ot appears to be okay for now.
  • whiteyluvsrum
    whiteyluvsrum
    cheers mate, will check it out.
  • aussiesport
    aussiesport
    yeppers was told the new cap and gasket will fix the problem !! soon find out i guess in to be done soon ....design fault ! or being cheap!! who knows for sure but its getting annopyng all these friggin things going wrong :/
