Burnt plastic on pipes.. Any ideas on how to remove it ?
  • Galloway
    Galloway
    Does anyone know how to remove burnt on  plastic from exhaust pipes.
    I think I must have hit a plastic bag and its left a very nasty mark.
    JG
  • Galloway
    Galloway
    Thanx guys,
    Some good ideas there I'll give them a try.
    JG
  • Galloway
    Galloway
    Good news... Its pretty much gone.. Thanks again for the feedback..
    JG
  • Destroyer
    Destroyer
    Oven cleaner works great, Then to get the last bit of crap off use 0000 steel wool and wd40/rp7.
  • robert65
    robert65
    Ahh yes the burn't plastic on the muffler trick! i used this one to customise my bike once very clever i know where you are going with this one! very very smart.
  • Galloway
    Galloway
    Oven cleaner followed by a LOT of rubbing with Autosol .
    Worked well
    JG
  • Lastrain
    Lastrain
    Nah .... good excuse for new pipes :D
