f#$%#en stupid alarm,battery charging troubles
  • nimo07sporty
    nimo07sporty
     i tried to remove my battery as per the shitty owners manual tonight as my battery is getting little lazy and i want to charge it overnight, i am a shift worker so i dont ride every single day and when i try to take off the fucking negative cable on the tranny the alarm goes off and im following the stupid manual what could be wrong? i just want to give my battery a good charge so i get a few more years out of it. any input would be much appreciated thanks heaps guys.
  • groover
    groover
    I put a trickle charger on my bike. just hook it up when I plan not to ride for a while.
    Makes you jump when the alarm suddenly goes off hey.... fucken loud in the garage as well.
  • nimo07sporty
    nimo07sporty
     yeah made me jump and hte missus ha ha ha , fucking annoying though als i want to d is charge the battery but maybe i cant do it , oh well fucking thing ill just have to ride more which is hard sometimes but thanks
  • nimo07sporty
    nimo07sporty
    yeah cool ill go have a look thanks mate,
  • nimo07sporty
    nimo07sporty
    just read the link you sent me and sounds like an idea to try so ill give that a go on days off and see what happens, thanks again for the advice
  • nimo07sporty
    nimo07sporty
    done the whole pull the main fuse out b4 alarm is set and it worked, now i just gotta put the battery back in and hope its charged it up will see lol
  • nimo07sporty
    nimo07sporty
    yeah everything went back to normal after i put battery back in, just had to reset the clock, but other than that bike runs fine and no other problems, to take battery out you need to turn ignition on then off and b4 the alarm activates you need to pull the main fuse on the positive terminal then youll be fine to remove battery as per manual, it worked for me cause i had same problems with alarm but removing the main 30 amp fuse breaks the circuit so all good after that. let us know how your install goes and if you have any problems rouge, laters
  • nimo07sporty
    nimo07sporty
    yeah hope the install goes well i want to do that for my next upgrade for my bike but funds are limited as you all know, so i hope that one day ill get to it im currently waiting for my sundowner seat to arrive from america then ill at least be able to ride in comfort for a long time hey keep us all posted on your progress rouge hope it all goes well thanks mate
  • als1200
    als1200
    3737pisces how did you get on. do you know what battery voltage you had using a multimeter? my ride was getting a bit lazy not long ago so after changing the battery it doesnt drop much below 12.9 volts now after sitting for up to 10 days.
