Online: Soapbox2627
Getting brave with the rattle can, new Bitchin Seats rotors for my Rocker...
  • kanunski
    kanunski
    Done a few bolts with the rattle can so far so am getting a bit brave / stupid, hope it works out as I expect:
    Bitchin Seat Rotors
  • Lastrain
    Lastrain
    Did you paint stright onto the polished surface ??? or was some prep work done?
  • kanunski
    kanunski
    Straight on but the can reckons that's fine, guess i'll find out if that was a dumb move.
  • kanunski
    kanunski
    It's been really good on the bolts so far and given a few coats it should hold well i hope.
  • Lastrain
    Lastrain
    Will still look shit hot, at least for a while, let us know how it goes I have been thinking of doing a few bits and pieces
    ... what kind of paint is it?
  • kanunski
    kanunski
     Two minor mistakes on the right hand side which i can prob patch up some how, it's also the rear and that side faces in to the wheel, otherwise they came up pretty good i think, be interesting to see it it lasts.
  • kanunski
    kanunski
    great tip thanks, i hadn't thought about that
    edit: worked a treat, a lot happier with it now, has come up a treat, also did the bolt heads and the flush mount front axle covers, going to look awesome when it's all on.
