Online: Soapbox2627
Ghost brackets and panniers from Kazz Mazz
  • LRPV
    LRPV
    G'day troops,
                           Anyone have a set of these or experience with them? They look the go and don't change the lines of the bike like the old wire-type pannier brackets.  Given my wallet isn't fat I want to check for any negatives before letting the moths out.
  • robert65
    robert65
    LRPV i have a set of ghost brackets and i reckon they are excellent , especially if ya don't want the bags on the bike all the time . they even lock up and the guys over there are very helpful. goodluck with ya choice.
  • TC
    TC
    LRPV
    Check the Dyna section under touring Dyna in 1min 30sec. In my opnion they are great value and quality.
  • Nibbla
    Nibbla
    LRPV,
    I have brackets & saddlebags from Kazz Mazz, very easy to fit /remove from the bike & they don't touch the paint, no scratches, they're great.
  • Dragon
    Dragon
    Yeah Nibbla, those saddle bags look great bouncing around. Have to get a pair for my bike
  • Peter
    Peter
    I have EASY BRACKETS which are the same thing but are the original. Both work brilliantly but i do remember reading something about the easy brackets that convinced me they were a bit better in the way they were made or fitted or finished or something. Ghost brackets are a copy of easy brackets but both will do the job.
  • dodge
    dodge
    Can't comment specifically on the brackets but you will not beat Kazzmazz for service.
  • LRPV
    LRPV
    Ok, thanks for the words guys. Sounds like a general thumbs-up for the brackets.
