Online: Soapbox2627
Using Mobil1 V-twin 21-W50 in 2008 Dyna Gearbox
  • vladt
    vladt
    Howdy All,
    I know this topic has already been done many times over but please bear with me.
    Lots of forums/riders and workshops recommend using Mobil1 V-Twin in all 3 holes. Even Harley recommend using their Syn3 in all 3 holes.
    I am not convinced so would ike to hear from anyone who has used Mobil1 V-Twin in their gearbox and their opinion.
    I also believe that viscosity rating of the gearbox oil isn't directly comparable to viscocity rating of the engine Oil. Thus 75w90 comparable to 10W30 engine oil. Is this correct?
    Vlad
  • wilso
    wilso
    I used to use the harley stuff in my 99 wideglide but found the gbox noisy - clunky on gear changes - mate of mine put me onto "Bel-Ray Big Twin Transmission Oil" - and so far it has worked wonders , once up to temp on a ride, gear changes are smooth as silk. i'd recommend it to all.
  • vladt
    vladt
    Problem with Redline is that our local stockists only keeps 5L container of it @ $152. Way too expensive, unless I can find somewhere a 1L container. So far no luck in Melbourne.
    Has anyone used Bel-Ray Big Twin Transmission Oil? Peter Stevens seems to be stockin in right now.
  • andij
    andij
    g/meikle hit it on the knob ,gear box oil for gears ,engine oil for engine ,the primary you can put olive oil in
  • MIKER
    MIKER
    HD 360 in the Donk , HD Formula + Gear & Primary oil , in the other 2 holes . i Drain all the holes every 2500km & my HD thrives on clean / fresh  Harley Davidson Brand oils .
    P.S i have used Mobil 1 V-Twin & cant justify the extra $$ , HD360 & Formula + Gear Box / Primary Oil's work just fine .
