Online: FONTANA302
Tyres
  • beagle
    beagle
    Has anybody been running metzlers. Thought I would try a set instead of the HD Dunlops on the Heritage. Would value any comments. Thanks in advance.
  • MJ
    MJ
    much better grip wet and dry, much easier to roll of the middle i feel alot more confident in tight corners till i start to scrap exhaust and side stand :D
    never felt that confident in the dunlops. i also have 16" front and rear tyres ......
    they wear real well except when ya do burn outs :D
  • matt08
    matt08
    i have 1 on the front and have no complaints , time will tell as to how well it wears . i got about 16k off the dunlop , pretty happy with that
  • Daniel
    Daniel
    good grip but less klm. one or the other im afraid.
  • MJ
    MJ
    i prefer the grip but much better k's compared to the pilot powers on the duc it only got 6000 to 8000 k's i have got 10000 out of the front so far and still heaps to go
  • Evo
    Evo
    Won't use anything else on my Heritage. Regularly get around 20,000 out of the rear and got 30,000 out off the front. Don't hoon on them and tend to ride long distance. Secret is to keep the pressures up. I run 39 rear and 34 front. Stix is right though, when they get past the halfway point, you need to adjust your riding style a tad.
  • andij
    andij
    the dunlop 407s arent bad 12000kl out of back ,best ive ever done ive run k591 v rated buy they wear quick and suare off with plenty tred on metz i agree with above,good for cafe and cruisin
  • Tapey
    Tapey
    I got 17k out of my Avons, front and back, gone to Metzler now but havn't got that many km's on them yet. Got a spare front Metzler sitting in the garage i won on a poker run so i hope they are good.
  • roadie
    roadie
    I found the dunlops terrible and wouldn't use them again. Hopeless grip in dry and scary in the wet. Harley uses them because they get a good deal with them. No different to manufacturers of any goods. I've used a couple of michelin commanders and found them good. Just trying avons now. Grip good so far.
  • beagle
    beagle
    Well folks,
    I've just got the metzlers on. Firstly, on the first corner, having a rear tyre that wasn't seriously squared off from doing highway miles was a bit different. Once they're scrubbed in I'll give them a proper shove and see what happens. The tread patterns a bit different, probably from looking at Dunlops for fifteen years. They were under $400 fitted so I really can't complain if I don't like them. Thank's for the interest shown by the feed back.
  • andij
    andij
  • andij
    andij
    all the tryes i had were good new its how they wear and handle towards the end of there milage ,some wear different hence different handling ,for wet weather goin slower is safest option ,tyre pressure is critical
