Crack, Snap & Pop (Not Rice Bubbles)
  • Burraburra
    Burraburra
    People,
    I have read some other post concerning "throttle off then the pipe go snap, crackle & pop".  Now the other post are concerned about the backfiring noise.  My bikle does similiar but it does not concern me?
    So, should I be concerned?  I have a new 2009 Softie Custom (500 klms).  Vance & Hines Sides Shot which necessitated I also get SE Race Tuner and SE Air Filter.   Any advice, comments (smart ass or otherwide) or recommendations welcome.
    Cheers Big Ears.
  • shaggz
    shaggz
    Well it seems that it does concern you now lol
  • Burraburra
    Burraburra
    Thanx Krash
    Smooth & strong.  no probs at all.
    well your sweet mate, if they hesitate or don't pull strong, they could need adjusting, but sounds ok to me. could just check your pipe gaskets that they are sealing & not letting air suck in.
  • Burraburra
    Burraburra
    Ok thanx for all that Krash.  I feel better ......
