Unused bike to do's
  • Hoodaman
    Hoodaman
    Ullo all..........
    Ye ol Blongmobile has been locked up in moth balls and unridden and unstarted (cause of its position in mates car hire cage) for the last 7 weeks now.... As i am still recovering from a shoulder reconstruction it looks as though it may be another month b4 it gets started or ridden again depending on how fast this prick of a shoulder lets me....
    Do ya think that will be ok to let sit or is there something i should do to prevent problems.????
    I didnt expect it to be mothballed for this long...
    Ta yoll....................
  • beagle
    beagle
     Usually a good polish and keep it loosely covered if possible. The battery may also need a kick along during this time and check the air in the tyres when you first start riding again.  Hope the after op aches settle down for you....beagle
  • Hoodaman
    Hoodaman
    Thank you matey............
  • Hoodaman
    Hoodaman
    Thanx lots guys i feel a lil better now...........Not too much to worry about..........I do have that same trickle charger so i guess i should go down and hook that one up...........
    My mind is at ease.........
  • SWIFTY
    SWIFTY
    il take her for a blat for ya hoody, just say the word.
  • Peter
    Peter
    Yep I'd be kicking her over every cupla weeks.
  • ductor
    ductor
    When you first get back on ride around slow with all brakes on to descale them. It may prevent panic on your first attempt to slow down.
  • Hoodaman
    Hoodaman
    thank you fellas..........could be a few weeks b4 i get back on............all suggestions heeded.............
