Online: Soapbox2627, Hilly
oil filter removal tool needed
  • berms
    berms
    I need to get an oil filter tool - I have seen the HD genuine cap style one with the special "cut out" HD-44067 something to do with the crank sensor??
    What do you all use??    My bike is 2010 touring model.
    Or there is this one http://www.eglidegoodies.com/id79.html
  • Dermie
    Dermie
    I needed one, just bought my sportster 1200c 2005 model with 1,900km on the clock a few days before xmas & it had not had its first (1,600km) service yet so I figured it at least an oil change. I went to super cheap autos or whatever they are called. They offered a variety of filter tools, I bought one that fitted on the end of the filter by gripping onto the knurled (indented) end of it & turned with a shifter on the end. So there is no issue with the bike frame being in the way.
    In fact I will now go & buy a bigger one for my ute which has a very inaccessible oil filter.
    The tool easily removed the old chrome filter, I replaced it with a new black filter. The tool put a slight scratch on the new black one, probably would not have affected a new chrome one.
    I cannot remember how much it cost, maybe $10 to $12.
  • Dermie
    Dermie
    Now that,s a good idea to drain the oil out first. How do you go with the advice in the owners manual where they say you should put some oil in it before putting it on. I spilt quite a bit of oil in that process.
  • berms
    berms
    Posted By gmeikle on 07 Jan 2010 8:05 PM
    I have this tool here on the shelf, and i use it on all Harleys. On my 2008 Softail with factory oil cooler it's the ONLY tool that will work without risking damage to the crank sensor.
    I just serviced a 2008 Dyna yesterday and it also needed this HD-44067 tool to clear all the regulator etc.
    The one shown in the link will work on some bikes but others have no access thru the frame downtubes to use it !!
    I bought mine from US ebay, $20.95 US plus post from a Harley dealer !! Aussie HD dealers don't seem to stock or sell "Factory tools".
    Try ebay US
    gmeikle, I tried Ebay for that tool that you have, but no luck....  (EDIT) I thought that tool I posted would be the next best thing? it says that it will work on bikes with crank position sensors?
    ..........Engineered for all late model ('90 and newer) Harley Davidsons using the stock filter with minimal clearance between the crankcase/sensor and the filter; it allows you to easily get in that tight spot to crack the filter loose without slipping........
  • berms
    berms
    Posted By Ando on 07 Jan 2010 8:22 PM
    Berms I got one from supercycles pretty cheap
    before that it was a screwdriver and hammer even now I punch a hole in the bottom of the filter to drain the oil out of the filter befor undoing it
    Thanks Ando, I will give Supercycles a call.
  • berms
    berms
    Posted By gmeikle on 07 Jan 2010 11:07 PM
    Just be careful that the Supercycles one has the "notch" or cutout in it. It is required as the alternator plug is pretty close !!
    I use mine even on bikes that don't need it as it's just so easy to use, requires a 3/8 stepdown to be used on a 1/2 inch driver.
    Yes, will do. Thanks..................
    EDIT found that a strap style filter remover tool will also work.
    Cheers.
  • CHARLIE
    CHARLIE
    STRAP TYPE IS THE WAY TO GO.
  • motor_head
    motor_head
    I been using a large hose clamp, just tighten it then tape the screw with screw driver and hammer.
  • berms
    berms
    Posted By motor_head on 09 Jan 2010 6:44 PM
    LOL thats actually not a bad idea............. as they say  "necessity is the mother of invention".
  • SWIFTY
    SWIFTY
    I use an old dog lead cut short near the looped handle and a made up t bar. roll the Tbar in to dog leash till it bites (loop around the fillter) bingo. used to do it the bucket way but this is cleaner and cheaper than the bought ones
  • Peter
    Peter
    I bought a BMW filter tool for my softy and just cut a piece out of it for the sensor. It is better quality than the HD one and less than half the price and fits perfectly. I'm not sure if it will fit yours though.
  • Lastrain
    Lastrain
    Have used lots of different shit in the past, everything from propper tools to rags wrapped around and twisted up tight, all sorts of old belts, best one to date cost me about $30 a few years back made by Caterpillar it is a metal rod thingy on a curved plate with a piece of seat belt nylon strap threaded through, 1/2" drive so can stick the ratchet/bar stright into it, can even plug extension into it for those tricky hard to get at spots, never come across a filter it wont fit or can't undo ... or do up, even used it to hold hydraulic cylinders and other stuff.
