Online: Merv
08 Dyna FXDC Air Filter Element
  • Purnong
    Purnong
    Can anyone tell me which after market air cleaner element fits the above bike
    I cant find anything on the K&n website specific for the 08 Dyna's with the teardrop air cleaner anywhere, Will the HD-1499 fit?
    Or any other manufacturers either
    I flicked off an email to K&N but thought I would ask here as well
  • kensim
    kensim
    i am not sure but in my opinon if u are going to change it go for an after market product, i got a screaming eagle and there a shit paper filter ,so i got a zippers cotton filter from m&m cycles in the states heaps cheaper than here have a look at there web site iam sure u will find want u want
  • cattleprod
    cattleprod
    Purnong. The K&N part number is HD-1499. well thats the one for the 07 FXDC anyway, me thinks will fit your 08.
    Around $100.00.
  • Purnong
    Purnong
    Thanks Cattleprod
    Did the 07 have the teardrop aircleaner cover?
    I still have'nt had a response from K&N, They're online catalogue shows nothing for 08 Dyna's
    It's looking like I might have to buy an aftermarket backing plate and go from there
  • cattleprod
    cattleprod
    Ya can see the original to your left.
    I ended up getting a round Ness backplate, element and cover.
    whilst your ac cover is teardrop, what shape is the actual air filter. You may find it is the same as the HD-1499... just a thought
