1200 custom suspension
  • duddles
    duddles
    i purchased a 2010 1200 custom and love the bike but notice every bump today i bought the shok tool and tightend the rear 3 or 4 turns bit better how do i adjust the front shocks
    I think you can add a heavier weight fork oil can't you? Someone will know...
  • duddles
    duddles
    wat can be done to front forks as every bump hurts
  • Jufster
    Jufster
    Duddles you can try a lighter weight fork oil, maybe some softer springs; the forks are not adjustable otherwise. There are heaps of shocks available aftermarket, lots like progressives, Ikons etc. I just spent bucketloads on some Fournales. There are some other posts on this forum that should give you some ideas. The sporty wasn't made for comfort!
