HD360 Oil
  • MIKER
    MIKER
    I just changed over to HD-360 Oil , after flushing out the Mobil 1 V-Twin on my last service i did . the cost of the Mobil 1 seems way over the top $20.00+ for 1 litre  , being i dump my oil every 2500km anyway i used HD-360 . Honestly my engine run exactly the same as it did when i had Mobil 1 in it , even on the hot 38 temp days . so i figured am just going to use Dino HD-360 for now & change it over evey 2500km as i do , most Harley Davidson workshop's use HD-360 for years without a problem to their customer's & @ approx $38.00 for a gallon it keep me  .
    p.s. this is just my opinion & not intended to cause any heated debate .
  • MIKER
    MIKER
    "MIXER"   no mate it's "MIKER"   , wise words you speak .
  • MIKER
    MIKER
    haha , no prob's mate .
  • joey
    joey
    MIKER if your doing it often enough, as you are at 2500k's, you don't need to waste your money on synthetic oils....... Simple...........
  • Tapey
    Tapey
    Just got my Mobil 1 for $14.60 a bottle. Was paying $22.00 from the bike shop...went to Mobil direct and got it for a much better price.
  • WAGlide
    WAGlide
    Did you have to buy a carton to get it at that price?
  • MIKER
    MIKER
    Now that i have run HD-360   in my FXSTC for the hot Aussie summer @ temp's of 42 + &  in heavy  traffic situations to open highway riding , i can honestly say that i cant Fault HD-360 oil in my Harley Davidson . i wouldnt bother to use anything else from this point on & am just going to regularly change my oil every 2500km & my Donk is running smoothly & didnt show sign's of overheating in hot temp & high stop - start use , am very impressed with HD-360 .  to think i nearly didnt use it (HD-360) , due to all the negative crap spoken by so called oil experts saying = "i must use expensive full syn oil's" , i say  use whatever you like in your HD "but IMO HD-360" works fine without a problem whats so ever & is good value $$ .
