white walls
  • jocky
    jocky
    just ageneral question guys, what is the best,way to cleen white walls. and the safest,,, as in no damage to the tyers.would app. an honest answer. thanks
  • Dragon
    Dragon
    www.wikipedia.com
    ......nahhh, they will probably bull shit to ya on that site
  • FXRfreak
    FXRfreak
    Ok, you asked for my honest opinion! And that is to get rid of the damn things, IMHO they are not worth the trouble to keep clean, you spend ages getting them perfect go for a ride and they are filthy again, they tend to show up every little bit of road grime, and even when the rest of your bike looks reasonably clean after a wash and a fine weather ride, your whitewalls always look grotty when ya get home. I would rather spend my time riding than cleaning stuff like that. They were on one of my bikes when I bought it, and by the time I needed new tyres 3 months later I was turned off them for life. Unless of course you have oodles and oodles of time up your sleeve to waste then go for it. I used to scrub mine with a detergent solution and a moderately stiff brush.
    FXRfreak
  • Fangio
    Fangio
    Honest opinion...don't have a farking clue...
  • jocky
    jocky
    it,s just that i am after adeluxe and it looks so good with the white walls, can i order one with out white walls, instead
  • Fangio
    Fangio
    IMO the white walls adds to the Deluxe look...sure brother i suppose you can order one without.
  • Kustomtown
    Kustomtown
    Mate, I have a Deluxe. Don't lose the white walls, they're easy to clean.
    Use Jif with a mild scourer. They come up a treat.
    That's all I've ever used and have no problems.
  • Kustomtown
    Kustomtown
    I should have said a scouring pad........not a dish scourer
  • Jake Adelaide
    Jake Adelaide
    Keep the Whities, go with the Jif.
  • FLSTC
    FLSTC
    change brake pads to Lindall . they dont leave brake dust. gone through one set of ww's now without having to scrub .
