Online: beaglebasher, softfat
new 96cu with 400km and tranny chain noise
  • LRPV
    LRPV
    Hi guys,
                   I was just running up the bike prior to a ride and I noticed what sounds like a chain knocking around in the tranny at the rear. Never heard this before. Any ideas? Its due for its first service on Tuesday but I don't want to ride it till then in case I damage anything.
  • LRPV
    LRPV
    It's a 2010 FXST.  I read elsewhere on this page some fast take offs in 1st with heavy rear braking can reset the primary. I just did that. The noise isn't as bad but its still there...
  • Lastrain
    Lastrain
    Had similar problem with my 09, dealer has even checked it out ... primary chain auto adjuster not adjusting properly, it can be "assisted" by giving a bit of a flick with a screwdriver or what you tried with a fast take off and heavy rear brake (no lock up's)
    I've just clocked nearly 6000 k and mine has stopped knocking now, I think it has just adjusted itself as it is ment to, the dealer mentioned they are getting a few newer bikes with the same problem and are talking to HD trying to get a fix for it.
    The dealer assured me it won't do any damage and is ok to ride.
    I would mention it to the dealer when you get your service done though.
