Online: John.R
Oil levels and sumps
  • Mungrel
    Mungrel
    Can someone please enlighten me .... in a normal engine, the sump holds all the oil, it is pumped up from there and returns to it. If you overfill, the crank starts splashing in the oil and it can get ugly.
    With the softail engine, the oil resevoir is not in the sump, but under the seat. So what happends if you overfill a bit? Does it matter? What controls the amount of oil in the actual engine? Never having pulled a Harley engine down, I don't fully understand the flow.
    Mungrel
  • lapua
    lapua
    CAN NOT HELP DIRECT WITH YOU THERE GO TO TUNEYOURHARLEY.COM OR JP CYCLES.COM CLICK ON TECH TAB OR CYCLE SPOT.COM HEAPS OF GOOD ADVICE THERE M8
