Online: Stuart
error code
  • taz
    taz
    Can someone help me I am getting a error code 1004 on my 2006 softtail .
    Does anyone no what this means bike still runs ok , but engine light comes on after I start it for about 4 seconds.
  • BACAMICK
    BACAMICK
    DTC FAULT CONDITION MODULE
    "BUS Er" Serial data bus shorted/low/open/high
    B0563 Battery Voltage High TSM/TSSM
    B1004 Fuel Level Sending Unit Low Instruments
    B1005 Fuel Level Sending Unit High/Open Instruments
    B1006 Accessory Line Over voltage Instruments
    B1007 Ignition Line Over voltage Instruments
    B1008 Reset Switch Closed Instruments
    B1122 Right turn output fault
    B1131 Alarm Output Low TSM/TSSM
    B1132 Alarm Output High TSM/TSSM
    B1134 Starter Output High TSM/TSSM
    B1135 Accelerometer Fault TSM/TSSM
    B1141 Ignition switch open/low
    B1151 Sidecar BAS Low TSM/TSSM
    B1152 Sidecar BAS High TSM/TSSM
    B1153 Sidecar BAS Out of Range TSM/TSSM
    P0106 MAP Sensor Rate of Range Error Carb
    P0107 Map Sensor Failed Open/Low Carb
    P0107 Map Sensor Open/Low EFI
    P0108 Map Sensor Failed High Carb
    P0108 Map Sensor High EFI
    P0112 IAT Sensor Voltage Low EFI
    P0113 IAT Sensor Voltage Open/High EFI
    P0117 ET Sensor Voltage Low EFI
    P0118 ET Sensor Voltage Open/High EFI
    P0122 TP Sensor Open/Low EFI
    P0123 TP Sensor High EFI
    P0131 Front 02 sensor low (lean)
    P0132 Engine running rich
    P0134 Front 02 sensor open/not responding
    P0151 Rear 02 sensor low (lean)
    P0152 Rear 02 sensor high (rich)
    P0154 Rear 02 sensor open/not responding
    P0261 Front Injector Open/Low EFI
    P0262 Front Injector High EFI
    P0263 Rear Injector Open/Low EFI
    P0264 Rear Injector High EFI
    P0373 CKP Sensor Intermittent Carb
    P0373 CKP Sensor Intermittent EFI
    P0374 CKP Sensor Not Detected Carb
    P0374 CKP Sensor Sync Error EFI
    P0501 VSS Low Carb
    P0501 VSS Low EFI
    P0502 VSS High/Open Carb
    P0502 VSS High/Open EFI
    P0505 Loss of Idle Sped Control EFI
    P0562 Battery Voltage Low Carb
    P0562 Battery Voltage Low EFI
    P0563 Battery Voltage High Carb
    P0563 Battery Voltage High EFI
    P0602 Calibration Memory Error Carb
    P0603 EEPROM Failure Carb
    P0603 ECM EEPROM Error EFI
    P0604 RAM Failure Carb
    P0605 Program Memory Error Carb
    P0605 ECM Flash Error EFI
    P0607 Converter Error Carb
    P0661 Intake solenoid low/open
    P0662 Intake solenoid high/shorted
    P1001 System Relay Coil Open/Low EFI
    P1002 System relay Coil High/Shorted EFI
    P1003 System relay Contacts Open EFI
    P1004 System Relay Contacts Closed EFI
    P1009 Incorrect Password Carb
    P1009 Incorrect Password EFI
    P1010 Missing Password Carb
    P1010 Missing Password EFI
    P1351 Front Ignition Open/Low Carb
    P1351 Front Ignition Open/Low EFI
    P1352 Front Ignition Coil High/Shorted Carb
    P1352 Front Ignition Coil High/Shorted EFI
    P1353 Front Cylinder No Combustion EFI
    P1354 Rear Ignition Coil Open/Low Carb
    P1354 Rear Ignition Coil Open/Low EFI
    P1355 Rear Ignition Coil High/Shorted Carb
    P1355 Rear Ignition Coil High/Shorted EFI
    P1356 Rear Cylinder No Combustion EFI
    P1357 Intermittent Secondary Front EFI
    P1358 Intermittent Secondary Rear EFI
    U1016 Loss of ICM/ECM Serial Data Instruments
    U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Power train Security Status TSM/TSSM
    U1064 Loss of TSM/TSSM Serial Data Carb
    U1064 Loss of TSM/TSSM Serial Data EFI
    U1064 Loss of TSM/TSSM Serial Data Instruments
    U1097 Loss of Speedometer Serial data Carb
    U1097 Loss of Speedometer Serial data EFI
    U1097 Loss of Speedometer Serial data TSM/TSSM
    U1255 Missing Message at Speedometer EFI
    U1255 Serial Data Error/Missing Message EFI
    U1255 Serial Data Error/Missing Message Instruments
    U1255 Serial Data Error/Missing Message TSM/TSSM
    U1300 Serial Data Low Carb
    U1300 Serial Data Low EFI
    U1300 Serial Data Low Instruments
    U1300 Serial Data Low TSM/TSSM
    U1301 Serial Data Open/High Carb
    U1301 Serial Data Open/High EFI
    U1301 Serial Data Open/High Instruments
    U1301 Serial Data Open/High TSM/TSSM
    2006 models with 02 sensors (Dynas)
    P0131 Front 02 sensor lean for any length of time
    P0151 Rear 02 sensor lean for any length of time
    Above codes can also be set if 02 sensor fails.
  • taz
    taz
    Thanks fellas for the input on error code problem.
    It has been solved now, had a mate come around told me it was a easy fix.
    (Seems I turned my ignition on before conecting all my blinker wires back together after I moved them hence the error code .)
    Did the reset on the speedo all fine now, he used the error code clearing & dtcs found in Reference Section on this site .
    Reference Doc/How to guides
  • Deadly
    Deadly
    Glad this one worked out for you
    Mate who races 600 supers had to tuck the indicators inside the body work untill the factory released a 'plug-in' to stop the motor shuting down because (from Yamaha) 'the ECU can't live with a blown bulb"
    ECU's have emotions and feelings to, Like shit they do!
  • AJ56
    AJ56
    Hi I got an error code P0661 (Intake Solenoid low/open)? Does anyone know that this means. FYI I have recently put on S&S slip on mufflers and that's all.
  • sophtayl
    sophtayl
    Did you change your air cleaner?
    This error code comes up when you unplug the intake actuator solenoid.
    heers
    Mick
