NEXT UPGRADE
  • LOW06
    LOW06
    Hey forumers, Im ready for next upgrade. So far SE pipes, air cleaner, ignition module and mikuni. Whats next without going to 1200. What about cams? How do they alter performance?Any other suggestions. Cheers Steve
  • Fangio
    Fangio
    go for it mate...go nuts
  • Jimmy Jazz
    Jimmy Jazz
    Maybe raise the tank 2 inches and put either apes or drag bars, maybe lower the rear with some progressives. Dont spend too much on a sporty, enjoy the bike and then when you are done with it get a fatboy lo. I've stopped spending money on my nightster. Why do you want to start frigging around with the engine? Sounds like youv've nearly done enough
  • LOW06
    LOW06
    Cheers jimmy jazz, maybe apes, forward controls and a brawler seat?
  • grafpak
    grafpak
    you can always go against the flock and not go to a fatboy!! just keep hotting up that sporty!!!!!!!!!!!!!!!!!!!!!
  • harrysboy
    harrysboy
    Yeah mate, get into the engine, up it to 1200, get a good head job, cams, pistons and get those 100 ponies (much cheaper than the fatboy too...).
  • LOW06
    LOW06
    I saw somewhere in the forum where a fella had done similiar to mine as well as andrews cams. How do aftermarket cams alter the performance of the bike?And jimmyjazz any photos of your ride?Steve
