Online: beaglebasher
Headlight change
  • grafpak
    grafpak
    hi hilly , what brend of light is it ?
  • OSP1340
    OSP1340
    Where did you get the headlight mount from? I need one for mine since I mounted the fatboy headlight.
  • braando
    braando
    I fitted a HID xenon conversion kit to my Duc mate and the difference is unbelievable.....I was able to hide the small ballast inside the headlight housing. I am tempted to try the same with my Dyna Hilly..............and they draw much less voltage mate..........
