Online: beaglebasher, softfat
Help please re Super Tuner, TTS or Thundermax
  • braando
    braando
    Hi Guys,
      I have an 09 Low Rider and have been able to fit  S&S baffles into my clogged up SE slipons........long story there but all is going well........i want to fit a heavy breather early in the new year and know that i will need to re-map it as it will be too lean,.so here is my dilemma.........one guy at Frasers swears by SE Super tuners.......another sais i would be better with the Thundermax as it replaces by existing unit. Only today in the forum i see the TTS name thrown around here .............  now i am confused........i am reasonably handy with fiddleing around with my bike but not an expert........handy with a computer though........can anyone with some knowledge here please give me some advice.........i live in Sydney ....Many thanks................Brian
  • braando
    braando
    many thanks for the help here.................will look into the TTS i think..............
  • Wildturkey
    Wildturkey
    i have a race tuner on mine goes really well
  • Lastrain
    Lastrain
    Have you considered the Big Joes Gen3 FuelShot?
    I too am weighing up which system would suit me best and do not know much about any of them. At present I am leaning toward the TTS as this is the most recommended or the FuelShot.
    From what I understand (fellas please correct me if I am wrong) the Fuelshot connects to your current ECM and is a set and forget unit that after initial setup will adjust itself as required without having to be connected to a laptop or put on a dyno, I have seen some pretty positive posts regarding it and sounds like a very simple system with very effective performance gains, and will also handle most configurations of bolt on performance goodies.
  • braando
    braando
    Many thanks guys.............will keep you posted.................
  • nimo07sporty
    nimo07sporty
    hi there i been looking at all sorts of tuners etc and i think youve jsut sold me on the tts as it seems soo simple, thanks alot mate, will let you know in future when i purchase one and start to play ha ha ha ha again thanks
