Online: Soapbox2627
Redline ATF for the primary
  • Lastrain
    Lastrain
    Anyone else out there tried Redline ATF in the primary ..... ????
    Recently had a problem with the primary auto tensioner not adjusting properly causing a "knock" when cold, apparently this is becoming common.
    Dealer checked it out did a manual adjust and put HD formula+ back in .... still knocked ..... rode for a few hundred km's and now no more "knock", I am thinking the adjuster has just clikced up another notch and solved the problem itself.
    Just want to see if the problem could be oil related, I did find a huge improvement in gear shifting with the ATF, it being thinner reduced drag between the clutch plates and smoothed the shift, I do want to go back to using the ATF but not if it causing problems with the auto tensioner.
  • CHARLIE
    CHARLIE
    HAVE RUN REDLINE HIGH-TEMP ATF IN MY PRIMARY ON THE ULTRA FOR YEARS BIG DIFFERANCE WITH CLUTCH OPERATION .CHARLIE
  • Lastrain
    Lastrain
    Thanks for the replys ... am feeling a bit more reassured that the oil was not related to the problem, it IS ok to use ATF and will go back to using the Redline High Temp ATF.
    :D
    I've had no problems useing ATF Type F made by Valvoline. i've clocked up about 80,000+?k's original primary chain original alternator 01 twin cam dyna & been drag racing it from year one. i'm not having problems so i'll stick to it.
