Online: Soapbox2627
Oil Draining into Sump
  • AJ56
    AJ56
    I have not ridden my bike since Tues Afternoon,  I checked my oil this morning and nothing showing on the dip stick at all.  I had a look with a torch and the oil level is right down...I checked my oil level Tuesday Night and at the correct level.  I know that it has drained down into the sump and that the oil pump will fix that when I start the bike.   But is that amount of time normal  for the oil to drain down into the sump or is it something I should be looking into getting looked at. Do the 07 Models have a one way valve fitted to them to stop this sort of stuff or is it just one of those things that are Harley typical.
    AJ
  • AJ56
    AJ56
    Thanks for that Scotty. My mind is at rest now. It done it a few weeks ago but it had been sitting around for weeks on end as I was away. I was worried that it happened over a shorter period of time.
  • AJ56
    AJ56
    Jesus your a cheap bastard I wanted at least 250!!!!!
