how far forward can u go on a fatboy?
  • wazza-in-oz
    wazza-in-oz
    Now i know i've read this somewhere but i cant find it in any posts.  I want to put forward controls on my 95 fatboy and am thinking about the 2" extended ones but i thought i read somewhere that you need to be careful because they can hit the front fender when turning.  Is this right?  Also can you get just 1" extended forwards?  Thanks.
  • The Don
    The Don
    Hi Wazza,
    I'm not sure about 1" over being available, you could modify the 2" over I suppose.
    I can tell you from personal experience that the 2" over will definitely contact the
    extended controls. I put a set of 2" over on my 89 Heritage, checked clearances
    and thought I was OK. I have a steep driveway and when I rode up and the front wheel
    hit the bump between my driveway and the road. I was turning left, and the fender hooked
    onto the master cylinder locking the front end and throwing me on a slow and not very graceful
    swan dive to the right.
    I was already late for work, so a quick dive to the garage and the trusty hacksaw took 3 inches
    off the bottom of the front fender in 2 minutes flat. Bugger, had to repaint anyway.
  • monarofan
    monarofan
    i've got 3 inch plates and aftermarket forwards on my 09 fatty with no clearance worries, i have seen 2 inch plate sets for sale
  • wazza-in-oz
    wazza-in-oz
    Thanks guys.  Interesting to read that the later models dont have clearence issues.  Looks like i might just fit the standard length forwards.  I'm 5 foot 10 so they should be fine ya think?
  • wazza-in-oz
    wazza-in-oz
    Just aded a picture of my bike to my profile so just posting to see if it worked
  • wazza-in-oz
    wazza-in-oz
    Nup.  Didn't work.  Damn!!!!
  • wazza-in-oz
    wazza-in-oz
    What year is your bike skulznflames?
  • wazza-in-oz
    wazza-in-oz
    Maybe all fattys and heritage bikes after 2000 don't have issues because the frames changed.  So with mine being a 95 model does this mean i can't have the 2" extended forwards?
  • MJ
    MJ
    the fatty gaurd is higher than the heritage.......
    i'm 5.9 and have standard forwards on and it is a comfy length
  • Sparra
    Sparra
    I'm looking for a 2" extension kit for my 95 FXSTC if anyone knows where to find them...
  • wazza-in-oz
    wazza-in-oz
    You can get 2" extensions on ebay.  Not sure how much they are.  I forgot that the heritage guard is bigger than the fatboy so i probably can go with 2" extensions if they feel better.  Thanks guys.
  • grafpak
    grafpak
    got 4.75 inch ext fwds on my sporty..you may be able to pack out the plates 5-10mm either side to help with clearance's..
