Online: John.R
Wider bars
  • keego33
    keego33
    How much wider than standard can you go before you have to start changing cables, wiring or brake line.
    I would like to put wider bars on the Sporty, anyone done this.
  • haynes-davidson
    haynes-davidson
    I've put on a 32 inch wide drag bars on mine and it's fine.
    I'm only concerned about wrist position as it's more comfortable
    with the stock handle bar.
