Online: Ronmac, beaglebasher
Burning Thighs !
  • MUSIC
    MUSIC
    Hi, recently after riding and stopping in traffic and lights the heat coming off the Bike. (ULTRA) is unbearable and is actually feeeling like it is buring my jeans. I have opened the little slots at the front of the bottom fairing but it makes 0 change unless your moving.
    Has anyone else exeperince this, as I have had 4 ultras from 1995 - 2008 and this bike is the one which I am feeling it the most.
    could it be the tuning making the engine too hot.
    I am not a techy, so have no idea.
    Have a good one.
    Love the ultra's.
    Thanks.
    Mal'
  • MUSIC
    MUSIC
    THATS AWESOME..... tnx.
  • blueystar
    blueystar
    MY FLHTCU HAS HEAT SHIELDS FITTERED MAKES A BIG DIFFERENTS TO HEAT OFF ENGINE
  • Dr Hog
    Dr Hog
    I had this problem on my Ultra
    Pipes, aircleaner and race tuner + these little plastic guards under the seat (they look ok) worked for me.
    it still gets hot though, I took the slides out from the lower guards and this improved it a lot. basically fixed except for bad traffic in the heat
    I prefer my dyna to ride, the ultra is not a town bike
    Good luck Music
  • barchem
    barchem
    I had the same problem on my 08 Road King . After trolling through the US HDForums I ordered some RJSOrigionals heat shields from the states - they are made from aluminium I think and covered in a vinyl very similar to the seat . They are simple to fit unlike the plastic Harley ones  and when complete if you email a phot of your bike to the maunfacturer/supplier they will check if you have them sitting correctly and they work very well . From the US HDForum site they appear to be th pick of them. Price from memory was US $140 plus freight. I also purchased some polished aluminium covers that cover the top half of the passing lamps from the same crowd  - seems brighter as it reflexts light back in and our bottom half of light and adds more chrome to the front. If I can find some time and work how to add photos I will add them ( Where do I look for instructions on adding photos ??)
    To find these heat shields google rjsoriginals       - excellent compant to deal with
    Barchem
  • MUSIC
    MUSIC
    Hye BLUEYSTAR, I ended up just getting the Harley Heat Shields fitted to the BIKE and WOW. What a diferance it has made when stopped in traffic. ALso on thehighway it seems to be running cooler. I also swapper the mirrors to the Glide Mirros which sit inside the fairig which really gives the bike new lines. More MODS coming. Waiting on the Bad Wetaher to lock h bike up in the garage.
  • blueystar
    blueystar
    THE HEAT SHIELDS UNDER THE SEAT WHERE ON THE BIKE WHEN I BROUGHT IT
    THERE HAS BEEN A LOT OF BLING FITTERED TO THE BIKE WHEN I PICKED IT UP WHICH WAS A BONUS
    AND THE BIG BONUS WAS THE 113 SE MOTOR WHICH HAS A LOT OF STING
    REMOVE THE H-WAY PEGS FROM THE FINGER BURNER AND NOW ON THE ROAD SWEEPER
    PITY THE MOTOR WONT FIT IN THE ROAD SWEEPER
  • MUSIC
    MUSIC
    113 !!! Nice one. I found the 110 on mine made a huge differance in the uphill rides. Love the extra torque... have nice weekend.
  • CHARLIE
    CHARLIE
    HD Part number is 58022-07A work terrific on my 03 Ultra.Charlie
