Online: Soapbox2627
2007 SERT
  • harleynt
    harleynt
    Hi All
    I purchased a 2007 fatty with a 2007 sert.
    The sert is married to the bike (so I am told).
    The sert had no cables so i used the cables i had off my 2005 sert
    My computer recognises the sert but  is unable to connect to the ecm.
    Is there any difference on the cables used to coonect to the ecm from the sert for sert models 2005 and 2007
    Many thanks in advance
    Don't mean to state the obvious, but are you plugged in to to the diagnostic port ?
    There is usually another 4 pin Deutsch plug that is identical. You need the one with 3 wires . Easy mistake.
  • harleynt
    harleynt
    Thank you for the quick response
    I will check the run switch ( though i thought i did check that)
    and recheck the connector and advise of the results
  • harleynt
    harleynt
    I finally managed to get my sert working.
    the dealer used their cables on my sert and on data load it worked
    when they tried it first with my cables it didnt work
    i exchanged each cable from theirs to mine one at a time to try to find which of my cables was faulty
    after exchanging both the sert was still working
    I conncted the sert at home with my laptop
    and now it works
    just to let anyone else who may have this problem
    try what i did
    theres no reason
    but it works
