Online: obisteve
RK engine mounts
  • Fr3d
    Fr3d
    I have done 40000 on my 08 RK and the front engine mount has collapsed. They are going to change in under warranty but I want to go the next step and put in better mounts.  I have been looking at the Glide Pro kit.  This includes a new swing arm pin and extra mount support as well as a new urethane front mount.
    Anyone know about the Glide Pro setup and are they worth the money?  Appreciate any feedback.  Thanks.
  • roadie
    roadie
    I don't know about the front mount but the swingarm kit gets good writeups. I believe the swingarm pivot bolt is stainless and much stronger. Also check out sta-bo which is just replacement bushes so a cheaper kit.
